Unreal plugin not working!
Hiya,
When I launch Unreal from Shotgrid Desktop like so:
I have the plugin enabled in UE4 and can see it in my toolbar. But when I click it, nothing happens. No response at all.
Here’s the UE4 output log. I can’t diagnose what the errors mean; I’m a bit stuck. Anyone know what the cause of this is?
This is a problem with authentication - it is trying to provide a command-line auth prompt, which does not work when the terminal is connected to Unreal - it is not interactive.
I’d try logging in on the website before opening. Not sure it’d work, though.
Thanks for the insightful response. Unfortunately I was already logged into the Shotgrid website when this happened, so no joy there.
I managed to find a solution to this, or at least a workaround. After some poking around in the Shotgun support docs I created a toolkit.ini file here (obviously I edited out the username!):
With only the username and my site inside like this:
and it seems to work consistently! Hurrah!
