Hi there,
I’m trying to use the create_filesystem_structure() function within SGTK to create and register directories for an asset.
Here’s a bare-bones version of my code:
mgr = sgtk.bootstrap.ToolkitManager()
mgr.base_configuration = DESCRIPTOR_STRING
mgr.plugin_id = "basic.testplugin"
engine = mgr.bootstrap_engine("tk-shell")
tk = engine.sgtk
sg_asset = tk.shotgun.find_one("Asset", [["id", "is", 100]])
tk.create_filesystem_structure("Asset", sg_asset["id"])
I get the following stack trace when attempting to run this code in several different python environments:
File "testscript.py", line 48, in <module>
File "...\cfg\install\core\python\tank\api.py", line 916, in create_filesystem_structure
folders = folder.process_filesystem_structure(
File "...\cfg\install\core\python\tank\folder\operations.py", line 219, in process_filesystem_structure
folders_created = io_receiver.execute_folder_creation()
File "...\cfg\install\core\python\tank\folder\folder_io.py", line 131, in execute_folder_creation
rd = path_cache.synchronize()
File "...\cfg\install\core\python\tank\path_cache.py", line 360, in synchronize
return self._do_full_sync(c)
File "...\cfg\install\core\python\tank\path_cache.py", line 639, in _do_full_sync
data = self._replay_folder_entities(cursor, max_event_log_id)
File "...\cfg\install\core\python\tank\path_cache.py", line 909, in _replay_folder_entities
sg_data = self._get_filesystem_location_entities(folder_ids=None)
File "...\cfg\install\core\python\tank\path_cache.py", line 861, in _get_filesystem_location_entities
"Project id: %s" % project_entity["id"]
TypeError: 'NoneType' object is not subscriptable
I’m probably missing something obvious here ![]()
Any help would be much appreciated!
