Tk-nuke-write node hotkeys?
Hey all,
This feels like it should be a simple question, but who knows, I’ve tried to get it working in the past and it obviously wasn’t as simple as I hoped it to be.
I would like to override the “W” hotkey in Nuke so that when my artists press “W”, it creates a Shotgun Write node instead of a normal Nuke Write node.
I’ve tried mapping it using the tk-nuke.yml menu_favourites block but I think I must have done something wrong…
Here is the code I had in tk-nuke.yml
# shot_step
settings.tk-nuke.shot_step:
  apps:
    tk-multi-loader2: "@settings.tk-multi-loader2.nuke.shot"
    tk-nuke-writenode: "@settings.tk-nuke-writenode.shot"
  menu_favourites:
  - {app_instance: tk-nuke-writenode, hotkey: W, name: "Write Node [Shotgun]" }
  - {app_instance: tk-multi-loader2, hotkey: R, name: Load... }
And my corresponding tk-nuke-writenode.yml
# shot
settings.tk-nuke-writenode.shot:
  template_script_work: nuke_shot_work
  write_nodes:
  - file_type: exr
    proxy_publish_template:
    proxy_render_template:
    publish_template: shot_render_publish_exr
    render_template: shot_render_work_exr
    settings:
      datatype: 16 bit half
    tank_type: Rendered Image
    tile_color: []
    promote_write_knobs: []
I have removed the extra text in both of those files but based on that, there must be something silly that I am not doing, can anyone give me a hand on how they implemented the hotkey?
-Alex
hey @Ahuge from 4 years in the future!
did you ever figure this one out? :slight_smile:
The workaround is forking the app or, easier, use a menu.py and add the shortcut commands in there and add them to a custom menu.
