Tk-multi-workfiles - 'saveas_default_name' setting
Hi there,
Sorry if this sounds as a stupid question but i’m trying to use the ‘saveas_default_name’ setting inside of ‘tk-multi-workfiles2.yml’ so that Maya automatically fills the ‘name’ field with the asset name when trying to save for the first time.
When i add that setting, the Maya reference box shows that the setting is no longer by default and displays the string i used.
But the problem is that the ‘name’ field is always automatically populated with the string ‘scene’.
What am I doing wrong here? What do I need to do to get the asset name by default when trying to save?
Thanks a lot in advance!
Francois
Hey @Debatty_Francois! A quick heads up I’ve moved this to the #pipeline category to get the right :eyes: on it.
Hi François –
I just tested this, and it worked for me. If I set a value for saveas_default_name, that’s what I get in the name field when I do a Shotgun-> File Save in Maya. There are a couple things to point out here:
  • I suspect that you set this value in the wrong environment – when you’re saving a file, for example, to a task an a pipeline step on an Asset, you’re in the asset_step environment. So, you’ll want to make sure you’re updating the correct settings – those that config/env/asset_step.yml includes.
In the Default Config, this would be the settings.tk-multi-workfiles2.asset_step block of config/env/includes/settings/tk-multi-workfiles2.yml (as seen below), but if your pipeline configuration is set up differently, this may vary.
  • Having said that, I don’t believe you can set saveas_default_name to a dynamic value – you can only use it with a static string.
  • What you might want to do is modify your templates in config/core/templates.yml so that instead of {name}, you’re using {Asset}. Note that if you don’t have a {name} field in your template, the text field in the File Save dialog will go away, and the file path will be fully automatically generated, with no input from the user.
Some relevant docs:
Hi Tannaz,
Thank you so much for the quick answer!
You’re right, I was setting the value in the wrong environment.
And modifying config/core/templates.yml gives me exactly what i was looking for!
Thank you again for your help and for the useful links.
Francois
I just thought I’d share this link, as Barbara provided a suggestion that allowed her to dynamically set the default save name:
https://groups.google.com/a/shotgunsoftware.com/forum/#!searchin/shotgun-dev/workfiles$20name|sort:date/shotgun-dev/RcbThuYFQuk/OmqQVZNJBAAJ
Hi Philip,
This solution looks pretty neat! I’ll give it a try :wink:
Francois
I know this is fairly old, but this solution works like a charm, thanks so much @blaigneau!
I had no clue you could trick string config values to be resolved with a core hook. I wonder if anyone has found a way for the hooks to not be core hooks, ie .being able to specify {engine} {config}, etc…
I wonder how this can be used to set name based on the pipeline step.
Because the bundle_obj.context has step/task/entity None when saving a new scene - there is only valid context.project.
The step/task/entity are still None regardless the selection in save dialog.
hello and thanks for the suggestion! very late in the game here and the link you provided does not seem to work anymore. any chance this is available elsewhere? :pray:
Here it is.
Add this to your core/hooks folder as custom_name_resolver_from_ctx.py
Then in workfiles2 you can add this to the saveas_default_name setting:
saveas_default_name: hook:custom_name_resolver_from_ctx:task_name
# -*- coding: utf-8 -*-
# Copyright (c) 2015 Mac Guff
# @author: Barbara Laigneau <barbara@dark-shot.com>
# @brief: Core Hook to get a name from a context
from sgtk import Hook
import os
class ProceduralNameFromContext(Hook):
    def execute(self, setting, bundle_obj, extra_params, **kwargs):
        Get a name from the current context
        :param setting: The name of the setting for which we are evaluating
                        In our example above, it would be template_snapshot.
        :param bundle_obj: The app, engine or framework object that the setting
                           is associated with.
        :param extra_params: List of options passed from the setting. If the settings
                             string is "hook:hook_name:foo:bar", extra_params would
                             be ['foo', 'bar']
        returns: needs to return the name of the file, as a string
        resolve_mode = extra_params[0]
        # the mode is basically the parameter passed from the config value - in this case task_name
        if resolve_mode == "task_name":
            ctx_task = bundle_obj.context.task
            return ctx_task["name"] if ctx_task else "scene"
        elif resolve_mode == "entity_name":
            ctx_entity = bundle_obj.context.entity
            return ctx_entity["name"] if ctx_entity else "scene"
        else:
            return "scene"
brilliant, thanks a bunch!
That’s very good, but WF2 can’t retrieve the task from selection, right? The context remains the same as the current open file.
It’d be awesome to retrieve the task from user selection and then set the file name parameter based on that information.
Ideally, it’d be possible to retrieve the name from the selected tasks, as shown in the image.
omg, I totally forgot you could create arbitrary hooks for settings values… ! That is awesome!
I think for that the tk-workfiles2 app would need to send out some sort of signal when you select the task, maybe it can set a runtime only app setting or simply an environment variable (TK_MULTI_WORKFILES2_CURRENT_SELECTED_TASK_ID).
Is that possible right now?
You’d have to fork the app and make that change but I’m just suggesting its a way to do it :slight_smile:
Altough there are probbaly more things that need to happen because the default_saveas_name function would need to be triggered every time you select a task.
It may make the app laggy.
