I was wondering if anyone has found we’re to change the value of the name field on the file save dialogue in the shotgrid menu. I want to override the default “scene” value displayed with a custom name value when the dialogue opens.
Hello @Frederick ,
Yes, you can do this.
Each app has an info.yml file to show you the settings that exist for it, so for your case, we have them here:
Here is an example in a branch of the config to change it from its’ default value of scene to filename :
Hope this helps, let us know if you need more guidance - cheers!
