Status Bug?
Hello!
I was changing Status in tabbed view, but now I can’t change it in tabbed view.
I can no longer click on it.
Please lend me your wisdom.
Hi Takahashi,
Can you provide a little more detail? Screenshots? What page/entity?
Thank you for your reply.
I used to be able to change the version status in a tabbed view, but when I try to add a status type, the version tab does not appear and I can’t click on it anymore.
I’ll need to see a screenshot to understand what you’re describing.
Sorry for the confusion.
I attach some screen shot!
The top screengrab is the “type” field, not the status field, so I’m not sure why you are using that as an example of it working.
What permission group is your user in?
It’s likely that you do not have permissions to edit Version status field values.
You could also compare the versions “created-by” field to see if you are able to edit your own Versions but not other users Versions.
Thank you for your response!
I sent the wrong Status to Trash, once I put it back in, it was fixed.
Thank you very much.
