I’m trying to find a way to use Create for our review workflow but as it was already mentioned before in other topics, it can’t properly display aces2065-1 exr files.
My hope is to configure the mov conversion Create does when you create a version with an exr sequence. As far as I understand when I add a cersion with exr files, it uses ffmpeg in the background and creates a mov file. Can I configure the settings of this process?
If it could export a rec709 converted version of the exr file with the correct data range than it would be fine for me but I couldn’t find where to change the settings, is it from the >Shotgrid Create> plugins> movieformats folder?
