RV toolkit engine not working after upgrading from RV2022 to RV2024
Hey everyone,
We recently upgraded RV to the latest version and the tk-rv engine has stopped working. Were there any particular upgrades in RV that we should be aware of to get our toolkit engine working again?
From the error logs, it seems like it’s trying to execute some base pipeline configuration hooks to bootstrap the engine, but the paths of these hooks are invalid paths within the RV installation directory and it’s unclear where these paths are being set.
Thanks in advance,
Vlasis
Can you post some tracebacks or log information?
Certainly:
ERROR: sgtk_rv_bootstrap:tk-rv bootstrapping process failed: The supplied core path '<RV_INSTALL_DIR>/src/sgtk/baked/plugin/bundle_cache/baked/tk-config-rv/v2.1.0-rc1/python' is not a valid directory.
<RV_INSTALL_DIR>: the location of RV on disk.
Where does this environment value point?
RV looks at that environment variable for its install path and derives packages from that.
Did you install/deploy RV in a more manual way or is it installed via the installer?
I’ve followed the flow of commands step by step using pdb, but it’s hard to pinpoint where that path is being generated, but I think that last “python” folder that gets appended to that path is wrong.
If you install RV with the installer I believe the RV_INSTALL_DIR environment variable is set on the system or Rv is able to determine where it was installed.
Hmm strange. RV_INSTALL_DIR seems to be empty at the point it tries to bootstrap the engine. RV was installed using Rez, but the way we used Rez here is basically configured to install a copy of everything into a final location on disk. I’ll take a closer look at this envar.
Sharing what we ended up doing to solve this in case it’s helpful to anyone else.
It turned out that between RV2022 and RV2024, RV now installs its own sgtk/tank libraries as part of its python pre-installed site packages. So effectively everything related to the toolkit was running through RV’s toolkit core. We have our own forked TK core so that wasn’t behaving nicely when bootstrapping. In the end we removed sgtk/tank from RV’s python folder, and RV now picks up our in-house TK core and that allowed us to run our own RV engine, same as before in RV2022.
