RV-2025.0.0 crash on startup when a third monitor is enabled
hello, i’m experiencing a weird issue where RV crashes on startup if I have 3 monitors enabled. The error does not occur with 1 or 2 monitors, and it doesn’t seem to be related to any specific monitor, it seems like that having a third one enabled causes the crash.
Here is the complete startup log:
/usr/local/RV-2025.0.0/bin/rv.bin
Version 2025.0.0 (RELEASE), built on Sep 3 2025 at 00:19:33 (HEAD=bbe1953 ([Open RV] da5b6526)).
Copyright (c) 2025 Autodesk, Inc. All Rights Reserved.
INFO: File logger path: /home/users/m.digiorgio/.local/share/TweakSoftware/RV/
Segmentation fault (core dumped)
i’m working on rocky linux 9.7 with a NVIDIA GeForce RTX 2070 and Driver Version: 580.126.09
do you have any suggestions? do you know if there is a way to set the default monitor where RV launches?
any feedback would be greatly appreciated
