Hi! Is there a way to reset vendor account to default? I see this is possible with the other group role permission but this one. Thanks in advance!!
Hi @macbeth,
Thank you for the question. Yes, unfortunately, there is no default Vendor role and you currently cannot reset a group to the default vendor permissions in the UI.
If you need to reset to the vendor defaults, please write in to support@shotgunsoftware.com but it is recommended to make a copy of your vendor group should you want to edit it.
More info here
Hope it helps,
Linda
Thanks another question for the Vendor account, in order for that permission role to see and play Versions, they have to be the ones who created it? Is there another way, to use this role the closest possible to the client site/account? Like share a playlist with the vendor user, Thanks!
