REST call to return entity ID
‘status’: 400,
‘code’: 104,
‘title’: ‘Create failed for [Version]. The value for the Version Name field is required to be unique.
Is it possible for this type of REST call to return the ID of the existing/clashing Version?
Thanks for reaching us. What language do you use? This is the manual for create a record.
Cheers
Loney
HI Jing
I’m using Python.
I’m aware of how to create a new entity using REST API- my Q was if it is possible to obtain entity data in the return data of a pre-existing entity - when trying to create an entity(Version in this example)
Hi @dduffy,
No, currently the API (REST or Python) does not return the ID of the conflicting record that violates the uniqueness constraint. I can definitely see how that would be useful, and I’d recommend submitting it as an idea to our product team.
For the time being, you can do a try/catch for this sort of error in your creation call. If it occurs, you can then perform a quick find using the Version name you just tried to create to get this info and report it back to the script/log/user.
Thanks Brandon
We are currently doing as you suggest with an additional find - was wondering if there was scope to catch the conflicting ID.
I’ll add to product team idea.
Cheers
