I am writing a new topic regarding this cause I was unable to find out a solution for my issue through the community posts.
I am new on using Shotgrid Toolkit and my goal is to test it to figure out if it could fit our needs. Then I maybe misunderstand some usages and concepts regarding it.
My needs for now are to be able to use differents roots for my config. I follows all the recommendation on this page:
So I modified the roots.yml file. And I assume I have properly set up my schema since I have no error when using SG Desktop.
On my Shotgrid’s Pipeline Configuration page I have setup the descriptor field as:
sgtk:descriptor:dev?windows_path=D:\Shotgrid\configs\tests_shotgun\dev_test
I also take care to remove all the os path and filled up the plugin id field. I do not have uploaded configuration anymore.
When I use the python console through the desktop and do try:
tk.roots
tk.pipeline_configuration.get_data_roots()
I do not have the correct informations.
On my understanding this is due because of the file roots.yml located in my local %APPDATA% folder is not up to date.
What I want to achieve is to update my configuration located here:
C:\Users\<username>\AppData\Roaming\Shotgun\<shotgrid_site>\p<pid>c<cid>.basic.desktop\cfg\config\core
Is there a way to properly update those file when doing some devs tests like this ?
Thanks a lot !
