Hello I have a question related to how to bulk data by when i want to edit information using a custom field.
So I had a list field and by when I want to bulk data from an excel sheet this is not matching.
Can someone help me with this?
Thank you
Thank you
It looks like you are importing bulk data for Tasks, but trying to set Asset values also…
You need to do this in 2 different imports. Likely you will want to bulk import the Asset fields to update the Assets, then do a separate bulk import of Task data
Thanks for the answer , i just solved the issue doing the bulks per page type . Cheers
