Playlist Panel is too narrow for version names
While testing out creative review we have found that the left “Playlist Panel“ which displays all the Versions is too narrow to display Version Names which makes it impossible to see the shot code of the Version in the sidebar. Given a standard example Version name like: PRJ_036_1000_cmp_v001 the sidebar will display this as: “PRJ_036…0_cmp_v001“ which cuts off the shot number. Unfortunately as the width of this element is relative to font-size, the issue occurs regardless of display size or zoom amount. Here are some proposed solutions:
  • Make the default sidebar width wider
  • Make the version name font smaller
  • Make the Sidebar resizable
  • Adjust ellipsis string truncation to only keep the last 4 characters (In most cases this would allow for displaying a shot code and version number)
Little things like this can make a huge difference!
Thank you for your feedback and suggestions! Are these in order of preference in terms of potential solutions?
