Creative Review Public Beta v0.221.0 Released
Hello everyone! Creative Review Public Beta v0.221.0 has been released which focuses on some improvements and bug fixes. Here are the highlights of what is new:
  • Version panel adjustments
  • Clear frame and clear all annotations menu
  • Open annotations in the player as a participant in Live Review
Release Notes
FEATURES
  • Version Panel Adjustments
    • Added version status indicator
    • Readjusted the sizing and layout
  • Clear Frame and Clear All Frames
    • Added dropdown menu for clearing frames in the annotation toolbar
    • Added hotkeys
      • “Clear current frame” = CRTL + D
      • “Clear all frames in the timeline” = SHIFT + D
    • Added confirmation dialog for clearing all frames
FIXES/IMPROVEMENTS
  • Live Review
    • Participants in collaboration mode can now view annotations from the notes panel in the player for everyone to see
  • Localization
    • Fixed various localization issues
  • Live Review
    • Fixed an issue with participants in presentation mode being able to access the version selector
    • Fixed an issue with the version selector getting stuck when another user is scrubbing on a version and the version changes
    • Fixed an issue with single point annotations from participants not being rendered by the host
  • Zoom/Pan
    • Fixed an issue with panning on windows
CAVEATS
  • Known Version Panel Bug
    • We are working on a patch to address the issues with version name spacing that will be released as soon as possible
    • It is currently not working as intended to break the version name onto two lines
    • On-hover tooltip for full Version name is also not working
About the Known Version Panel Bug - noting this is currently truncating the version name - the hover-over pop-up is also not working, is that on your bug list too?
Both are known issues that we are working on and should be released in a patch early next week. I will adjust the original post to include the on-hover tooltip for the version name. Thank you and we’ll get this fix out ASAP.
Just wanted to follow up, the issue with the truncated version name not wrapping to two lines in the version panel should be fixed in a patch that was released today. Let us know if you are still having issues!
Hey all,
We’re seeing a couple issues with the Creative Review.
The status field on the Media Information panel is flickering between statuses. When clicked the entire side panel jumps as-if it’s scrolling then goes back into position. (Status Art is our sg_status_list)
CleanShot 2026-04-01 at 18.06.49
We see this behavior across any version.
We’re also noticing that playing a version in context with its uploaded cut doesn’t do anything.
Thank you for the feedback! I am logging those and will reach back out for any more information to reproduce the issues.
Are both of these issues new with the latest release or have they been ongoing issues?
Also could you outline the steps taken to upload the cut, version, and attempt to playback in context? We are working on better cut support now so I want to check how the versions are transcoded and the method in which the cuts are being imported into FPT.
We are having issues with Cuts in Creative Review behaving differently than they do in the standard player.
I’ve created a very simple 2 shot cut which plays as expected in the standard player(“Play in Browser” from the Media context). However, in Creative Review, when I am in a Cut context, I see the shots playing their full lengths and not respecting the in/outs set in the Cut.
Hey Michael,
The flickering issue is new with this latest release. We haven’t seen it before, though we don’t use Creative Review frequently enough to rule out earlier occurrences.
Regarding the playback in context issue: cuts are uploaded via the Import Cut Tool in RV, and Versions are uploaded manually to ShotGrid through the New Version form, using SG’s standard transcoder.
Steps to reproduce: I opened a playlist in Creative Review, then selected the latest editorial version on the “No Context” selector, and nothing would load.
UPDATE: while writing this, I left the tab in the background for a bit, and it loaded the editorial cut. When refreshing it took about 20 seconds to load without much feedback from the app, which is confusing and unpredictable.
However, this comes with an error: it doesn’t play at the correct framerate (it plays at 23.976fps regardless of the cut’s or version’s actual framerates of 25fps).
Here’s the info for that cut:
And the playlist versions:
Thanks again
Thank you both for the additional information. We are making it a priority to look into Cuts and fixing or clarifying any issues that may be happening.
