Nuke Studio integration
Hi @Osama.Ali,
Are you using the Basic Integrations? I’m not seeing the workfiles2 app in your log or current apps, this is a part of the advanced configuration of toolkit as it requires knowledge of the filesystem locations.
Can you let us know if you have set up the advanced configuration? The NukeStudio exporter needs the advanced setup to run.
-David
