Not able to update task status and shot status on shotgrid
Hi team,
we are created new permission page for peoples . which are access below fields only.
Changing shot status,
Changing task status
but our artists not able to change task status and shot status.
Please give solution.
Hi Guys ,
Any solution for above given issue.
I have the same issue, some permissions are locked. Others are enable but artists can’t modify status…
I tried to duplicate permissions… But I have always the same problem with artists…
Each individual status has a permission as well, for example, you can make sure artists can only change a Version Status from new to rev.
You can check and edit these setting by right clicking the Status field → Configure Field → Permissions → Open the permission group of your choice and edit the edit from and edit to checkboxes as you like.
Hello @Ricardo_Musch
Thanks for your answer.
What means the * next to the Artist ?
