Build #2020.02.026 - February 12, 2020
Features/Polish
- [Player] Apple ProRes and DNxHR are now supported in Create. [VMR-2651]
- [Player] Variable frame rate is now supported in Create. [VMR-2844]
- [Player] Improved performances when loading media in draft mode. [VMR-2841]
- [Send for Review] Send for Review introduces a new workflow between Maya/Photoshop and Shotgun Create. You can now send playblast or image as a draft to Shotgun Create, which put Create in version draft mode, where you can submit a review. [VMR-2289]
For more info, please refer to Shotgun Integration 1.3 Release Notes - [Screen Record] Visual improvements to the Screen Record UI. [VMR-2624]
Fixed bugs
- [General] Disabled users show as “Retired user” in Create, as if they have been retired or trashed. [VMR-2706]
- [General] SGC_NETWORK_PROXY setting is not applied to the login page. [VMR-2889]
- [My Tasks] Task with no project will stop Create from loading. [VMR-2774]
- [Player] Top and right hand panel flyouts very aggressive, makes it difficult to click the full screen toggle. [VMR-2798]
- [Player] Creating a new version in an empty task makes the Timeline unusable. [VMR-2784]
- [Player] Player randomly shows a black screen when loading media. [VMR-2853]
- [Player] File sequence parsing can make the application crash. [VMR-2893]
- [Player] When Player controls are hidden, player control hotkeys are not working anymore. [VMR-2830]
- [Player] Player’s spinner appears too often if no playback has been performed.[VMR-2920]
- [Player] Enable/Disable loop during playback stops it. [VMR-2778]
- [Screen Record] Single click on selecting region breaks Record or Capture flows. [VMR-2381]
Full Release Notes for all Create releases can always be found at: https://support.shotgunsoftware.com/hc/en-us/articles/360011473553-Shotgun-Create-Release-Note
