New build of Create available !
Build #2019.10.018 - October 7, 2019
Features/Polish
- [Thumbnails] Filmstrips are now integrated in Create and have a new algorithm that prioritizes frames with annotations. This means you always see the most important frames when you scrub directly in the image thumbnail everywhere in the application. [VMR-1473]
- [Audio] Audio can be heard on scrub. [VMR-505]
- [Screen Capture] Better feedback to user in the screen capture UI. A countdown and a red pulse have been added. [VMR-2365]
- [Annotations] Performance improvement during playback on frames with annotations. [SGC-1289]
Fixed bugs
- [File sequence] On Mac, file sequences are now loading properly. [VMR-2598]
- [Annotations] Toggling Hold/Ghost settings doesn’t stop the playback anymore. [VMR-2675]
- [Task view] Info panel UI is not crashing anymore when it needs to display fields using a checkbox. [VMR-2538]
Full Release Notes for all Create releases can always be found at: Help
“Audio can be heard on scrub” has resulted in at least one person on my team doing the full Carlton dance. Woo-hoo!
Shotgun Create’s got me all…
New build available !
Build #2019.10.074 - October 29, 2019
Features/Polish
[File Sequences] It is now possible to modify the source FPS to a custom value while creating a version. [VMR-2392]
[Compare] It’s now possible to compare two pieces of media while in draft mode. [VMR-2009]
Fixed bugs
[Annotations] Annotation responsiveness decreases over time. [VMR-1718]
[Open in DCC] “Open in…” doesn’t work anymore after Create version gets updated with Auto-update ON. [VMR-2704]
[Task View] Application crashes when selecting certain tasks with missing metadata.[VMR-2702]
[Task View] Getting “Something went wrong” when clicking on a task with missing info. [VMR-2673]
[Task View] Pending notes/versions should have a placeholder image as their thumbnail. [VMR-2667]
[My Tasks] Users get “It looks like you’re not a member of any Projects” error on login even if they are part of a project. [VMR-2639]
[My Tasks] Task’s unread status (blue dot) is not displayed anymore. [VMR-2701]
[My Tasks] Tasks without a version should have their thumbnail greyed out. [VMR-2658]
[Surface support] On a Surface, the app sometimes crashes when scrolling in the Task Board and in Conversation while images are loading. [VMR-2656]
[Player] Media representation option is not properly applied in Compare mode. [VMR-2677]
[Player] Player Initial state is not preserved when toggling from full-screen mode to normal. [VMR-1975]
[Login] Can’t login back after the session has expired. [VMR-2665]
[Login] Getting “Invalid site error” message after a connection time out. [VMR-2515]
[Login] Typing in the Site URL field after using wrong credentials throws a login error window. [VMR-1791]
[Compare] Latest compare mode is not kept anymore. [VMR-2283]
[Fullscreen] Addressed multiple issues related to fullscreen mode. [VMR-2267]
- Fullscreen button was missing in Compare mode
- Annotation bar was not properly hidden in fullscreen mode
- Some flyout menus sometimes remaining visible in fullscreen mode
- Improve UI usability with the Wacom Tablet
[Localization] Application ignores the user language settings. [VMR-2010]
[General] Application gets frozen when running while computer get into sleep mode. [VMR-1645]
[File Sequences] If a file sequence has special characters in its name, it won’t be possible to open it. [SGC-1209]
Full Release Notes for all Create releases can always be found at: https://support.shotgunsoftware.com/hc/en-us/articles/360011473553-Shotgun-Create-Release-Note
Build #2019.11.033 - November 20, 2019
Features/Polish
[Screen Record] Audio is now supported in screen record. [VMR-2297]
- Ability to enable/disable audio recording
- Visual indicator of audio being recorded
[Timeline] New Loop button available in the Timeline. [VMR-2616]
Fixed bugs
[Compare] Compare UI is broken when entering Compare mode from a draft version. [VMR-2759]
[General] Task status flyout menu has no scrollbar. [VMR-1890]
[My Tasks] Resizing the application in Task board eventually crashes the UI. [VMR-2596]
[Player] Annotated frame cue mark is shifting when changing the file sequence’s FPS. [VMR-2711]
[Screen Record] UI gets black using the Screen Record on Windows. [VMR-2642]
[Screen Record] Could get error: “Had Trouble loading the media” when recording. [VMR-2671]
NOTE: This also includes last release (2019.11.033) that was rolled back because of the Photoshop regression.
Build #2019.11.049 - December 3, 2019
Fixed bugs
[Toolkit] Photoshop integration is broken. [VMR-2796]
[Toolkit] “Open In Shotgun Create” brings user to an empty project state when launched from Shotgun “My Tasks” page. [VMR-2785]
Build #2019.12.001 - December 3, 2019
Fixed bugs
[Toolkit] Shotgun integration is broken in Maya. [VMR-2831]
Build #2019.12.020 - December 11, 2019
Feature/Polish
[Screen Record] Add quality management capability to Screen Record and set default format to 1920x1080, 30fps. [SGC-1327]
Fixed bug
[Screen Record] Screenshot resolution is not good when having 2 monitors. [VMR-2793]
