If your config is based on our old config (tk-config-default2) and you’re thinking of updating to the new config, (tk-config-default2) then you’ll need to understand what’s changed in the new config and how to apply your customizations over to the new config.
First off we have this which talks about the changes that were brought in with the basic integrations (tk-config-basic). Some of what is covered here also applies to tk-config-default2.
Differences
The key changes between the configs are as such.
A new environment YAML structure. The deafult2 config now has a much more modular structure, where includes (
@) are used much more to split the configuration out over multiple files. This makes it much easier to see the settings for a particular app or engine in one config. Before theenv/project.ymlfile would contain the majority engines and apps that were required for theProjectcontext, now these are all separated out and chained together using the @ syntax.
For example the project.yml links out to the Maya settings:
https://github.com/shotgunsoftware/tk-config-default2/blob/v1.2.11/env/project.yml#L41
which are stored here:
https://github.com/shotgunsoftware/tk-config-default2/blob/v1.2.11/env/includes/settings/tk-maya.yml#L61
That, in turn, links out to separate files for apps, frameworks and locations.
The “Editing a config” and “Adding an app” guides may provide some help here. -
No
shotgun_{entity_type}.ymlfiles. Previously there were files like shotgun_project.yml which were used to define the apps available for the browser integration. Now, however the logic for deciding the environment to use for thetk-shotgunengine runs through thepick_environment.ymlwhich brings it in line with everything else. So your normal environment YAML files now containtk-shotgunengine sections as well. If however, you don’t have atk-shotgunengine defined in your environment YAML, it will still fall back to looking for ashotgun_{entity_type}.ymlfile. -
Software entities. The majority of the software launchers are now controlled via software entities.
The schema and templates haven’t really changed much.
The
tk-multi-launchapphooks, have changed to allow working with Software entities. As there is now a generic settings block used for all software defined by Software entities, the hooks now include the engine name in the passed args. This is because it is a generic settings block, when you define your custom hook, it will be called for all software, so you need to use theengine_nameparameter to check if it is an engine you want to act on, before doing any software specific logic. -
New publish2 app. The hooks and settings here are very different from the first app. You can find the publish2 app reference documentation here and a this tutorial covers writing plugins/hooks for them.
Strategies for updating.
There isn’t a golden path here as such.
The first thing you should do is figure out what you have customized on your current config. Performing a dif between our old default config and your existing one would quickly show you what you have changed.
Once you’re aware of the changes you can then start working through them and applying them to the new config. There isn’t a simple apply changes approach here, you will need to translate your app settings over to the new environment YAML structure. Templates and schema can probably be directly copied.
For somethings, it might be better to test out the new config’s settings before deciding to carry over old settings.
Please feel free to post below if you discover something worth mentioning that I missed or have any questions around it!
