Hi Sophia,
It should be easy enough for you to modify the loader via a config file, in the default “advanced” config it would be this file here:
{config}/env/includes/settings/tk-multi-loader2.yml
The way the tabs are structured is very flexible depending on how you configure them. The key for you might be to add or modify the entities section to include a new Tab for Groups, or to place the group field in the hierarchy of another tab.
Here is an example of something I just configured while working on our Photoshop Integration:
By comparing this and the different things in the config file, you might be able to figure out how to achieve what you’re asking about.
settings.tk-multi-loader2.photoshop.asset:
action_mappings:
Rendered Image: [ add_as_a_layer ]
Texture: [ add_as_a_layer ]
entities:
- caption: Current Asset
entity_type: Version
filters:
- [ project, is, '{context.project}' ]
- [ entity, is, '{context.entity}' ]
- [ sg_status_list, is, apr ]
- [ published_files, is_not, null ]
hierarchy: [ sg_task, code ]
- caption: Parent Asset
filters:
- [ entity.Asset.assets, is, '{context.entity}' ]
hierarchy: [ sg_task.Task.step ]
- caption: All Assets
filters:
- [ entity, type_is, Asset ]
- [ entity.Asset.sg_status_list, is_not, omt ]
hierarchy: [ entity.Asset.sg_asset_type, entity, sg_task.Task.step ]
