Hi, I am trying to integrate the tk-premiere as per the steps in the Wiki. I am trying from a stand-alone machine without any firewall or restrictions.
I am getting TankDescriptorIOError: Failed to download into path C:\Users\ADMIN\AppData\Roaming\Shotgun\bundle_cache\tmp\34e72cdd556f47cc8495a423e49787df: Failed to download Toolkit App Store Framework tk-framework-lmv v0.2.2. Error: Failed to download from 'https://tank.shotgunstudio.com' after 5 retries. See error log for details.
Kindly guide on how to build the zxp and integrate with Shotgun Toolkit.
Thank you. Make.log (9.0 KB)
Thanks for replying. No I checked, there is 25+ Gigs of free space on hard disk , even Memory usage in Task Manager is around 50-60% Used, and I ran Command Prompt as Administrator.
Perhaps the path length is too long.
Try setting the env variable SHOTGUN_HOME to somewhere on another drive, preferably closest to the root possible.
Then start a new Sg desktop (it will be completely fresh as it will look at the new dir).
Then try your method.
On Windows theer is a 255 character path limit by default (which can be disabled via the policy editor or registry).
This has caused me issues before as well.
I then installed the plugin using tool from aescripts site. On launching Premiere directly from Start Menu, I faced the attached error. I am unable to get the full path in error. Read couple of log files of Premiere, but no luck.
Thanks Ricardo, I tried to configure, but I am not able to get Premiere icon visible in Shotgun Desktop App UI. I did the steps mentioned tk-premiere(wiki) . Thank you for helping me reach this far.
Yes, from that wiki page, I did these steps
5. Add Premiere Project item to Shotgun’s Published File Types page.
6. Add Adobe Premiere Pro CC to Shotgun’s Software page. Upload the Pr icon.
Is there anything more to be done on Site ? I am being a bit naïve.
This should definitely show the Premiere icon somewhere in Sg desktop.
Take a look at your tk-desktop.yml settings and potentially remove any edits you did for tk-premiere.
Also, obviously, reload the project for this to show.
Thank you, there was a typo in tk-desktop.yml. I missed the second * before "
groups:
matches:
- "*Premiere*"
Now, Premiere is launched from SG Desktop, however that error is still coming related to sg_constants when Premiere startup as I posted before. I felt this file is related but seems ok to me. (changed .js to .log) constants_js.log (2.9 KB)
I’m trying to get this up and working too, but I’ve hit an issue.
I’ve made the package, all my pipeline config setup looks good, but when I launch Premier, my extensions menu looks wrong.
After doing “make sign” are there any missing steps to intall the extension?
Thanks in advance for your help!
p.
Looks like I’m close. After moving the framework to the C: root so it has a small path, Premier is now loading from SG Desktop and the panel is available.
When I open it, I get this error now :
Checking the manifest in my appdata location, it doesn’t have the manifest from the custom framework (the reference to ppro is missing)… how do I force update the com.sg.basic.adobe folder?
