I am using Shotgrid’s Import Tool and there is an inherent error with shots that involve retimed clips. The cut duration is wrong whenever a retimed clip is applied. If I have to remove the retime every time I attempt tp populate a Clip Duration column that adds a lot of redundancy to my workflow. How do I get around this error? Thank you.
Related topics
Topic | Replies | Views | Activity | |
Import Cut Duration Not coming in | 0 | 272 | October 29, 2021 | |
Import EDL from Avid into Existing Shots | 2 | 1279 | August 4, 2021 | |
Import Cut Tool | 1 | 584 | July 25, 2022 | |
Not Shots created using Import Cut Tool | 0 | 206 | October 19, 2023 | |
Error when creating shots from Excel sheet | 6 | 2194 | April 3, 2020 |
