How to customize shotgun_fields_config_standard.mu to look at a custom field on Versions (only for SR for RV, not SGR)
We are using RV and I am curious is there a way how to customize shotgun_fields_config_standard.mu to look at a custom field on Versions (only for SR for RV, not SGR)?
The easiest would be to take a look at the shotgun fields config.
  • RV_INSTALL_PATH/PlugIns/Mu/shotgun_fields_config_standard.mu
    You can define new media entries here, and it’s a relatively easy process.
    And then you can post the config somewhere on a network path, and users can grab it and patch their RV version.
  • And here’s some docs
