How do I re-setup a Toolkit project using Shotgun Desktop?
If you’ve already set up a Toolkit configuration for a project and need to start fresh, the Advanced Setup Wizard in Shotgun Desktop will not allow you to re-setup the project unless you’ve removed the previously setup configuration.
Here is the portal to the doc you could follow:
