I’ve noticed that the History Options are disabled when viewing playlists in RV. Is there a setting somewhere that unlocks the history of Versions for playlists? History Options work fine when viewing assets or sequences directly.
Hi @stavernia,
The History Options are available only when looking at a portion of the version hierarchy. For instance, if you are browsing a Sequence, the history options will provide the historical linking between shots which displays versions.
Unfortunately, history options are not available for Playlists. For playlists, your best bet is to utilize the Related Versions tab in the info panel. You could right click on the certain version and Compare with Current.
Ben
