Git Configure Error
Hello
Attempting to set up Git configuration via shotgrid desktop.
I have set up the workflow and created a commit and still not sure the error.
As the message says, it will be easier to see the detailed log.
But I wonder if github requires authentication to clone through https.
You could try with a local repo, and you paste the path to it in the text box.
As mmoshev says, it may well be an authentication issue. I see that message when having issues with the companies proxy - I have to turn on and off some system environment variables (in my case relating to pointing towards our https proxy) for certain other programs, and if I don’t turn a specific one back on, git can’t communicate and that error gets thrown.
