SG Desktop SSL: Certificate_Verify_Failed
I just installed the last SG Desktop and I can not login.
There is and error about SSL. I never see it before, any clue?
Captura de pantalla 2022-09-06 a les 16.37.44
can you verify the version of ShotGrid desktop you have installed and if your system has an environment variable called SHOTGUN_API_CACERTS set?
Also, on that machine/user did you logon to the ShotGrid website before trying to login to SG desktop?
Are you sure you’ve entered the correct URL for your ShotGrid site? I doubt it starts with www.
Sometimes a firewall can cause a response that generates this error as well so you may want to look at that possibility.
KP
Good one for spotting that!
Mostly SG sites don’t have www indeed!
Thanks to all!
Fixed using solutions from:
btw, it could have been caused by the TYPO:
ttps >>>> https
or the H letter is just cropped :smiley:
