We are setting our firewall to reach autodesk login site to migrate ours accounts from Shotgrid.
So we need to know the FQDNs and IP addresses required.
We were trying with the following list but it does not work for us
Best Regards!!
Best Regards!!
The list you cite should be correct, mainly the section that mentions Login, License Entitlement
Unfortunately, the IPs of these site do change. We do not have a fixed list, we just have the URLs.
Just to isolate the problem, and remove ShotGrid from the equation, can you do a test and report back on the results ?
Network tabhttps://profile.autodesk.com
You can use that information to update your firewall settings.
Hoping this helps,
-Patrick
May I suggest that you instead post the errors you are seeing when accessing https://profile.autodesk.com ?
Notably:
Again, I recommend using an incognito window, to properly isolate the test.
-Patrick
