Firewall configuration and IP's
Hi
We are configuring an internal server for webhooks and want to make sure that the security is as restricted as possible but without loosing any functionality on the webhooks system.
Just want to confirm which ip ranges will be used for this service, is only the same as the main Shotgun service ?
Any other one we should be aware off ?
Hey @hasielhassan—I pinged the webhooks folks to confirm. :slight_smile:
Hi @hasielhassan - We are currently looking into this. The source IP of HTTP calls coming from Autodesk are typically not published because they could change over time. We’re checking to see if we could get official source IP’s for our Webhooks triggers.
We got an update!
Whitelisting these IP’s should work:
  • 34.200.155.69
  • 34.224.232.103
  • 34.202.127.170
The only thing is that I’m told these will change sometime during the second half of 2021 but after that, we should have a permanent list.
Thanks @daigles!
Will test this and let you if its working properly, we totally understand if they need to change from time to time, so as long as you let us know in advanced it should be fine :slight_smile:
Just want to report that this seems to be working perfectly, thanks so much!
Great!
Thanks for reporting this!
Should we be worried about these values changing soon?
just bumping this as I am wanting to whitelist the correct IPs now for webhooks
apparently the above listed IPs are still “it”
Dear Community
For any of you who are still using the IPs that were listed in this thread please read this new announcement as these IPs will change soon. Please reply in this other article.
Thanks for your collaboration
Hi Frank, not sure you are still dependent on these IP values. If so then please read this article
Hello, not sure you are still dependent on these IP values. If so then please read this article
If someone is still experiencing connection issues even after whitelisting the IPs ShotGrid provides, it’s worth checking if an external factor like an ipstresser attack might be causing disruptions. A sudden spike in traffic or strange patterns in network activity could indicate interference. I had to coordinate with IT to monitor and log traffic in real time to rule out this kind of issue before narrowing down firewall adjustments.
