We’re getting this error when trying to Open File in any DCC during the context change:
TankError: Tried to resolve a path from the template <Sgtk TemplatePath shot_work_area_maya: work/{Episode}/{sg_sq_short_name}/{sg_short_name}/{Step}/maya> and a set of input fields '{'sg_sq_short_name': 's0400', 'Step': 'AN', 'Episode': 'eall'}' but the following required fields were missing from the input: ['sg_short_name'] //
The shot entity does include the sg_short_name and when I run the folders or preview_folder command , they work and also output the correct path.
I think this maybe cause by incorrect filter in the shot.yml file but not sure. This is what I have:
type: "shotgun_entity"
entity_type: "Shot"
filters: [ { "path": "sg_sequence", "relation": "is", "values": [ "$sequence" ] } ]
- The folder creation resolves correctly
- The shot’s
sg_short_namefields does have a correct value
Thanks in advance for your input.
Cheers
