Display all records of an entity type
How do I display, for example, all the Sequence entities in SG across all projects?
Hi Clint,
You want all the sequence names for all the projects on one page, correct? If so, the solution is to make a new blank page, choose grid as the view type andand then choose sequence as the entity type. Then, build the view or new page. Attached an image for your reference.
You will be able to view every sequence in every project to which you have access.
Thank you much!
