CSV Import Errors
Hi All,
I’m trying to import data from Excel CSV into a page where all the fields match the column headers perfectly. However every way i try to import the data it matches the fields during bulk import but all of the data is in a single cell.
I’ve tried copying and pasting the data, saving out as .xlsx and .csv and get the same result with all.
Any ideas?
Jimmy
One idea is to first do a csv export from SG to create an import template
Thank you that worked. I think it must have been an issue with the header naming causing the initial import issue.
Thanks again
