This is a bug report regarding RV Screening Room .
When you provide a path without a file name or extension to path_to_movie, RV doesn’t display anything. However, it works fine when I use the same path in path_to_frames.
I would appreciate if Screening Room could skip the error and only show Streaming when this issue occurs.
Error message:
screening room: Source does not exist for Version with id: <exists version number>
screening room: _prefs.loadMedia Movie
screening room: Cannot load path <data of path_to_movie>. Directories are not supported!
The view is showing the message, “Screening Room Sequence – Empty”.
The version number exists on ShotGrid. And when I remove all paths in path_to_movie, it works.
