Batch publishing from standalone publisher
I was wondering if there is a way to separate out the assets from the tasks when batch publishing files from the standalone publisher . For instance if I wanted to republish all of the model tasks in a project due to an update. Currently in the standalone publisher it seems to be that you would have to choose a task for each one of the files in-order for them to go to the proper place.
Part of our current process saves a dcc_state and a publish_tree for the most resent publish. would it be a better idea to make an app that runs all the publishes using these files?
Can you give us an example as I’m trying top understand exactly why or what you want to do :slight_smile:
Currently the standalone publisher is on a per asset basis.
so if I had a list of 20 assets that I needed to republish I would have to select the task for each of these assets instead of just selecting the overall task such as ā€˜model’ and have it just recognize that it is a model publish for all of these assets.
I’m trying to see if there is a way that you can batch publish under a certain task type instead of just from and asset by asset basis.
Hmm, but you are linking each of them as well right?
You don’t ā€œhave toā€ select a task.
Where do these files come from?
Aren’t they published from within maya?
Hi @Dfulton1,
Thanks for clarifying your need.
Not sure if there is a way to publish by task type with the Standalone publisher.For batch publishing with it, I think the post below may bring you some inspiration.
Ben
