A new version of tk-nuke has been released!
Welcome to the release notes for this Engine. Below you will find an overview of all the changes we did for each release. We try to be as detailed as possible and include all bugs we have fixed, features we have added and things that may have changed. If you have questions about a particular release, don't hesitate to contact our support team!
v0.14.2
2021-Dec-1
Replacing shotgunsoftware urls with Autodesk Knowledge Network and ShotGrid Developer Documentation pages.
v0.14.3
2022-Jan-21
Updates Nuke version to support 13.1
v0.14.4
2022-Mar-28
ShotGrid branding updates.
v0.14.5
2022-Dec-7
Formalizing Python2.6 deprecation.
Fix error with web login.
v0.14.6
2023-July-25
Introduces the 'allow_keep_context_from_project' engine setting that avoids the ShotGrid menu from being disabled when for example someone opens a file with Nuke's File --> Open, that does not reside in any known project path. Also Updated latest Nuke supported version to v14.0.
v0.14.7
2023-Sep-26
Official support for Nuke 14
v0.15.1
2024-May-7
Add support for Nuke 15
v0.15.2
2024-Sep-09
Rename the use_sgtk_as_menu_name setting to use_short_menu_name
v0.15.3
2024-Sep-26
Add support to Nuke 15.1
v0.15.4
2025-Feb-06
Reverts Hiero log level after emitting a log message. Thanks to @reformstudios
v0.15.5
2025-Mar-11
Removed Python 2 code.
v0.15.6
2025-May-12
What's Changed
  • Add support for Nuke 16
  • Replace mock
  • Remove yaml deprecation warning
v0.16.0
What's Changed
  • Removed dependence to the ensure_binary and ensure_str methods (SG-39698)
  • Removed dependence on sgutils package (SG-39698)
  • Replaced imp module with importlib since it's not supported by Python 3.12 (SG-15664)
  • Skip unit tests for Nuke versions lower than 10 (SG-40319)
v0.16.3
Dropped old tk-core compatibility, cleaned up code and tests. Added Nuke 17 support.
What's Changed
  • Support Nuke 17 (SG-42791 - PR #129)
  • Dropped compatibility with tk-core versions prior to v0.22.6 (SG-40476 - PR #123)
  • Removed tests for Nuke versions below 10 (SG-40319 - PR #126)
Full Changelog: https://github.com/shotgunsoftware/tk-nuke/compare/v0.16.2...v0.16.3
v0.16.4
Fixed Nuke/Hiero project path issue when Local Storage is set to a Windows drive such as "Q:/". (SG-37411 - PR #131)
New Contributors
  • @yungsiow made their first contribution in https://github.com/shotgunsoftware/tk-nuke/pull/131
Full Changelog: https://github.com/shotgunsoftware/tk-nuke/compare/v0.16.3...v0.16.4
v0.17.0
Drop Python 3.7 support and Close Toolkit panels when Nuke quits.
What's Changed
  • Drop Python 3.7 support (SG-43666 - #133)
  • Nuke 16 shows its crash report after quitting when it was launched with Toolkit and the Flow Production Tracking panel is docked, as it is with the default config. This closes the docked Toolkit panels when Nuke quits, so their apps shut down cleanly before Qt destroys them (SG-38745 - #140)
Full Changelog: https://github.com/shotgunsoftware/tk-nuke/compare/v0.16.4...v0.17.0
