Release date: May 5th, 2025 ET
We released the following updates since 8.73:
Improvements
Conditional formatting
The description of a conditional formatting rule now also appears as a tooltip.
When you create rule-based (conditional) formatting, you can enter short text to describe the purpose and function of the rule. This descriptive text is now also displayed as a tooltip when the mouse hovers on the formatted field.
Note:
If the field has a description, that description supersedes the conditional formatting tooltip.
Documentation
To learn more about the conditional formatting, check out our documentation here.
Widget Sorting
Quickly sort the widgets of the Filter with the new Sort menu.
You can sort the widgets using the following criteria:
- By Count: Orders the widget results by the number of matching records.
- Alphabetically: Orders the widget results in alphabetical order.
- By Status: Orders the widget results according to the order you set in the Configure Field…
- By Date: Orders the widget results by date.
The available sort options depend on the field type. For example:
- Status type fields can be sorted by count, alphabetically, or by status order.
- Entity type fields can be sorted only by count or alphabetically.
Documentation
To learn more about the widgets, check out our documentation here.
Currency Fields
You can now display a currency symbol in Currency fields.
You can now display one of six common currency symbols, or enter a custom one. The currency is always displayed to the left of the value. This only displays a currency symbol, it doesn’t perform any currency conversion.
Note that an admin can prevent currency symbols from showing with the preference in Site Preferences > Language and Formatting > Display currency sign for currency fields.
Documentation
To learn more about the Currency field, check out our documentation here.
Bulk data importer
- Added a separate Bulk Data Import permissions checkbox. [SG-36455]
Task Status Field
- Improved performance when enabling a Task Status for all projects, especially when a site has a lot of statuses and permissions groups. [SG-38468]
