Release date: April 7th, 2025 ET
We released the following updates since 8.72:
Bug fix
Permissions
- Fixed an issue where changing a checkbox status in permissions for a non-admin role, when having ‘access admin functionality’ enabled, would apply the change to the admin role instead. [SG-38309]
Task Templates
- Fixed an issue where, in some rare cases, users with the ‘See all project’ permission disabled would encounter an ‘Oops’ error when re-applying a Task Template. [35034]
WebHooks
- Fixed an issue where, in some rare cases, WebHooks could not be received. [SG-37986]
Media Accessibility Restrictions
- Fixed an issue where users with the ‘Can See Media Download Links in FPTR’ feature disabled would still be able to access uploaded files via a link in the File/Link field type. [SG-37881]
Subscription Manager
- Increased the time-out period to load the Subscription Manager page when a site has large teams. [SG-37212]
Statuses
- Fixed an issue where status name would not displayed when a user does not have editing status permission. [SG-36737]
Entity Import
- Fixed an issue where Shots import would fail in some rare cases if the data contains existing sequence and shot. [SG-37898]
Linked Fields
- Fixed an issue where adding a new item to a list type field would result in an error, if the field was added as a linked field. [SG-37224]
Browser Notifications
- Fixed an issue where browser desktop notifications are not triggered if FPTR site tab is not in focus. [SG-35410]
Improvements
Graph Widgets
- Display the full status name in the calculated field output on graph reports. [SG-36262]
Notes
- Fixed an issue where Markdown heading syntax would not be recognized in a Note’s body. [SG-36033]
v8.73.0.6288 (build 99c30ebcaa)
Improvements
Conditional formatting
The description of a conditional formatting rule now also appears as a tooltip.
When you create rule-based (conditional) formatting, you can enter short text to describe the purpose and function of the rule. This descriptive text is now also displayed as a tooltip when the mouse hovers on the formatted field.
Note:
If the field has a description, that description supersedes the conditional formatting tooltip.
Documentation
To learn more about the conditional formatting, check out our documentation here.
Widget Sorting
Quickly sort the widgets of the Filter with the new Sort menu.
You can sort the widgets using the following criteria:
- By Count: Orders the widget results by the number of matching records.
- Alphabetically: Orders the widget results in alphabetical order.
- By Status: Orders the widget results according to the order you set in the Configure Field…
- By Date: Orders the widget results by date.
The available sort options depend on the field type. For example:
- Status type fields can be sorted by count, alphabetically, or by status order.
- Entity type fields can be sorted only by count or alphabetically.
Documentation
To learn more about the widgets, check out our documentation here.
Currency Fields
You can now display a currency symbol in Currency fields.
You can now display one of six common currency symbols, or enter a custom one. The currency is always displayed to the left of the value. This only displays a currency symbol, it doesn’t perform any currency conversion.
Note that an admin can prevent currency symbols from showing with the preference in Site Preferences > Language and Formatting > Display currency sign for currency fields.
Documentation
To learn more about the Currency field, check out our documentation here.
