8.71 Release Notes
Release date: January 16th, 2025 ET
We released the following updates since 8.70:
Improvement
User Menu
  • The “Email Us” menu item now opens a new tab for easier access. [SG-37194]
Bug fix
Calculated Fields
  • Fixed an issue where WORKDAY function would not properly handle empty values. [SG-36379]
Local files linking
  • Fixed an issue where local file linking would select incorrect local storage entity in some rare cases. [SG- 35577]
v8.71.0.5912 (build 138b4a7667)
Bug fix
License seats
  • Fixed a visual issue where a total and available seats number gets updated only in a few minutes, rather than immediately after a user activation / de-activation. [SG-37807]
Tasks
  • Fixed a visual issue where no horizontal scroll bar appears on the Tasks page if there are no records. [SG- 37289]
  • Fixed an issue where Gantt chart would display a workday rule for a group (as if on vacation) if a user and a group had same ID and a task was assigned to a user with a workday rule. [SG-36573]
v8.71.0.5956 (build 2165b800f0)
Improvement
Conditional Formatting Tooltips
The description of a conditional formatting rule now also appears as a tooltip.
When you create rule-based (conditional) formatting, you can enter short text to describe the purpose and function of the rule. This descriptive text is now also displayed as a tooltip when the mouse hovers on the formatted field.
Note:
If the field has a description, that description supersedes the conditional formatting tooltip.
wn-conditional-formatting-tooltip
Documentation
To learn more about the conditional formatting, check out our documentation here.
v8.71.0.6026 (build 637ea7d0bf)
Bug fix
Connection Entities
  • Fixed an issue where sending some Connection Entities to trash would result in an Oops error. [SG-30840]
Entity Statuses
  • Fixed an issue where changing the visibility rule of multiple statuses on an entity’s page would not always be applied to all selected statuses. [SG-36514]
Tasks
  • Fixed an issue where a group could not be revived if there was a task assigned to it. [SG-37991]
