Release date: August 13, 2024 ET
We released the following updates since 8.65:
Improvements:
Use Flow Generative Scheduling to quickly generate scenarios of a schedule imported from Flow Production Tracking.
Look at the presentation video here!
Schedules are commonly built on estimates and assumptions, but inevitably things change during the lifecycle of a project. The project schedule needs to be continually adjusted to accommodate changes in constraints.
However, adjusting and re-leveling a schedule is time consuming. Staying ahead of changing project requirements quickly becomes unmanageable, and ensuring that your schedule continually matches your project’s needs can feel impossible.
This is where Flow Generative Scheduling aims to help, by providing you with the ability to create realistic and balanced schedules that are easy to explore and adjust throughout the lifecycle of your project.
Accessing Flow Generative Scheduling
Flow Generative Scheduling is part of the Flow Production Tracking subscription. Your administrator gives you access to it from Flow Production Tracking. Once you have access, you can launch Flow Generative Scheduling from the Apps menu.
Documentation
To learn more about the Flow Generative Scheduling, check out our documentation here .
Work Schedules
- Added the ability to edit a Work Schedule exception. [SG-35649]
Bug fixes:
Canvas Widget - Graph
- Fixed an issue where a graph’s widget legend would not be sorted when displaying month names
Entity Importer
- Fixed a regression where a match would not be found when importing a thumbnail having
Ensure unique values per projecton Shot Code field. [SG-35304]
Fields (Administration)
- Fixed an issue where in some rare cases emptying a query field condition could result in thumbnails appearing in other projects. [SG-33942]
- Fixed a minor visual regression where Code field on the Project’s Advanced Creation Form would be displayed as “Project Name”. [SG-35566]
Notes
- Fixed an issue where in some cases a version would be filtered out if it has a draft note. [SG-35207]
Page Settings
- Fixed a regression where clicking on “View full changes to the saved filter group(s) and conditions” on Page Settings History would display no data. [SG-35177]
People
- Improved experience when trying to recover from any user control failure from People page. [SG-35100]
Queries
- Fixed a regression where a query field would display an empty cell if the query was based on a bubble field displaying a version’s thumbnail. [SG-35900]
Screening Room
- Fixed an issue in Screening Room where the Cut Mode won’t turn off. [SG-35383]
