Release date: November 23, 2021
We released the following updates since 8.31:
Improvements
Webhooks General Availability
Attention Pipeline Developers! Webhooks has moved from public beta into general availability for all users
. Included with with this update:
- Strengthened feature offerings, like bulk delivery
- Added UI and email warnings for problems with a Developer’s webhook endpoints
- Performed system maintenance ahead of anticipated increased load
- Improved performance during continuous deployment
- Improved robustness in case of network and infrastructure disruptions
- Improved system monitoring and automated alerts
- Many fixed bugs, informed by the public beta
Learn more about Webhooks here.
Pipeline Step Enhancements
Attention Admins and Producers! We’ve made improvements to your Pipeline management workflow experience!
When you create a new Pipeline Step , you will be presented with options on where you would like to display them:
- All unarchived Projects
- Only the current Project
- Select unarchived and template Projects
Select unarchived and template Projects allows you to select which projects you would like Pipeline Steps visible in. You can search projects, sort by the fields provided on Projects, and select the projects you would like the field and status visible in.
This functionality is available throughout the ShotGrid interface: from an entity page (like Shots, Assets, Levels, etc.), the Pipeline Management Page—where you can create new Pipeline Steps from, and within Project Tracking Settings.
Learn more about Configuring Pipeline Steps here.
Other Improvements:
- Quick Search field selections now persist and are saved in page settings after refreshing a page [SG-23688]
Fixed bugs
- Fixed UI visibility rules that were being applied to summary cells by reverse association [SG-23522]
- Fixed an issue which could occur when creating or editing a query field with a list type field condition [SG-24440]
- Fixed an issue where hidden entities were shown in the importer and grid cell editor [SG-22843]
- Fixed crashes that occurred when attempting to filter rows by Frame Rate [SG-16545]
- Fixed Issues in the Apply New field to Project dialog [SG-24021]
- Fixed an issue where adding a new status or a field to a selected project template added them to all projects
- Fixed an issue where adding a field to all unarchived projects actually only added the field to the current project
- Fixed a bug that was setting the year to the current one whenever a date was changed [SG-23976]
- Fixed a new Webhooks UI regression where it was not possible to add a new (additional) filter to a Webhook [SG-24531]
