Hi, I’m a bit new to shotgrid.
I wondered if there is any way to make a filter that compare names of last versions of different pipeline steps.
I’d like to only have the asset that don’t have the same version !
Thanks for your help
Hi @Ben ,
A distinct constraint is not a thing a filter would allow you to do in ShotGrid.
Best option is to use the API (python is probably easiest).
I think in the SG-Webinterface you can only achieve this with a workaround. I would approach it as follows:
Goto a Versions list and tick the “latest” checkbox:
