I made the rookie mistake of creating a shot in SG, then running the Create Folder script, then realising I created the wrong shot and renaming it without unregistering the folder first.
Later I tried to create a new shot with the same name I gave the other one originally, but when trying to run Create Folder on this I get:
Folder creation aborted: The path /path/to/shot/seq2/shot2 cannot be processed because it is already associated with Shot shot1 (id 8817) in Shotgun. You are now trying to associate it with Shot shot2 (id 8871). If you want to unregister your previously created folders, you can run the following command: tank unregister_folders /path/to/shot/seq2/shot2
Trying this gives me:
WARNING: Path
‘/path/to/shot/seq2/shot2’ is not
registered in Shotgun - ignoring.
No associated folders found!
same goes for the original seq1/shot1, and addressing the shot id direclty.
I tried deleting the shots and creating them again, but to no avail.
Is there anything that can be done? I would be ok with completing deleting them in SG and starting fresh, but I don’t know how (they still show up in the trash)
