I’m getting this type of error more and more. Sometimes I can unregister the asset, sometimes the tasks, but it doesn’t always work. Neither does unregistering the path. Sometimes deleting the path_cache.db in the local project cache helps. But only if the filesystem locations on SG have been unregistered / cleaned up.
How do you all fix this?
tank.errors.TankError: Database concurrency problems: The path ‘<Path\To\Asset\dev’ is already associated with SG entity {‘type’: ‘Step’, ‘id’: 110, ‘name’: ‘development’}. Please re-run folder creation to try again.
