Tk-multi-workfiles2 - Save and set status to 'in progress'
Is there a way to automatically set the status of a task to ‘in progress’ once a scene has been saved under that task?
You could take over the scene_operation_<engine_name>.py hook for the Workfiles2 app.
Then under the save function add your code to change the status of the current task as required.
As Ricardo already mentioned you could use a hook. And then get the task and if it exists, change the status. I recommend creating a framework for that. So that you can re-use the same functionality in different custom apps, not only in workfiles.
Inside the hook, you can use something like this, but I highly recommend adding all sorts of checks for your schema and available statuses.
sg = engine.shotgun
context = engine.context
current_task = context.task
if not current_task:
    return False
data = {
        'sg_status_list': 'ip',
sg.update(
            current_task['type'],
            current_task['id'],
            data
