Text in Publish GUI
In the After Effects Publish dialog, I would like to grab the text in the Description area:
I’m wondering if that is possible, and if so, how would that be accomplished. I basically understand how to override the tk-multi-publish2 hook, but I don’t know how to grab the Description text from the GUI.
-cn
Hi Craig
I believe, although I’ve not tested on my side, you should be able to access the description from a publish hook via the item.description:
https://developer.shotgunsoftware.com/tk-multi-publish2/api.html#tk_multi_publish2.api.PublishItem.description
Best
Phil
Hi Philip,
Yes, item.description works perfectly. Thanks so much!
Craig
