Tk-multi-publish2 item.description not in ui
Hello everbody,
I am currently updating our modified multi-publish2 app from v.2.5.2 to v.2.5.5 where the description inheritance is fixed.
But now I have the problem, that I can’t set an item.description in my hook, so that it shows up in the ui.
I can log the item.description, so I know there are information available.
And despite the label saying, Description not inherited, the tree_item.inherit_description variable is True.
I thought I might change the dialog.py file, so that it fits my needs.
I added the following code into the _create_item_details method:
context_item = self.ui.items_tree.topLevelItem(1)   # item after summary_item in tree
    for child_index in range(context_item.childCount()):
        if tree_item is context_item.child(child_index):
            tree_item.inherit_description = False
            break
But then there are other problems so far. For example that child-tasks do not inherit, whatever is set in the nuke.session item. Only when I change the ui manually, it shows up correctly.
If I omit the check if the tree_item is the first after the context and set the tree_item.inherit_description variable to False right away, the ui is correct on startup, but not when I enter something manually.
Is this a bug or is it not planned to have a default/previously saved item.description? Is there a way to set the inheritance of the tree items in the hook, because it may be the case you want a default description on a different level?
Also maybe a check on the dialog startup would be great, if an item.description is present and set it accordingly to not interfer with manual ui changes.
Cheers and thanks,
Henna
I can confirm I ran into this as well!
This never got a reply but I can confirm it’s still an issue.
We cannot set item descriptions from the collector anymore which is a big sad… :frowning:
Sorry to resurrect a dead thread but did anyone ever find a solve for this?
Having the same issue where I want to pre-populate the description when the publisher is opened.
Do it in a accept stage of a hook?
No dice :confused: I’ve tried this in the accept, and validate portions of the hook:
    item.description = 'THIS IS A TEST'
    item.parent.description = 'THIS IS A TEST'
nothing seems to reach the description box in the UI. I’ve also tried setting the description within the collection stage on the newly created item and still nada.
I also have this problem. This bug has been kicking around for 4 years now. Did you submit a ticket to AD support? I’m going to send one now.
Setting this to False allows my descriptions to appear, but it disables description inheritance globally.
Is there any way to access a TreeNodeItem from a PublishItem instance?
It appears there’s no way to configure description inheritance for a given publish item from any hooks.
