Hi everyone,
I am trying to run tank command from my config and throws this error, anyone knows how to fix it?
Error:
Welcome to SGTK!
For documentation, see https://developer.shotgridsoftware.com
Starting Toolkit for your current path
‘T:\lb_dev\fcrespo\projects_code\test\sg_tk_config’
- The path is not associated with any SG object.
- Falling back on default project settings.
ERROR: The path ‘P:\project\test_toolkit_toolkit’ associated with Project id
188 does not resolve correctly. This may be an indication of an issue with the
local storage setup. Please contact support at
Contact Customer Support | Autodesk Support.
File Management:
I have tried looking in roots.yml
primary:
default: true
linux_path: null
mac_path: null
shotgun_storage_id: 3
windows_path: P:\project
pipeline_configuration.yml:
pc_id: 928
pc_name: DEV_fcrespo
project_id: 188
project_name: test_toolkit
published_file_entity_type: PublishedFile
use_shotgun_path_cache: true
Any clue? thanks in advance
