In RV what’s the preferred location to store custom ‘global’ data to the RV session?
I’m looking to persist some custom metadata for the RV session files so I can access that data again when I reopen the session.
Should you store the data on the /root node that seems to always exist in the sessions?
Or is it recommended to create a custom node in the session? That however might require to define a custom node type itself too - or maybe there’s some sort of metadata nodetype to use for that instead? I couldn’t quickly find anything that made sense other than that Root node type or maybe the RVSession node type.
