Shotgun PhotoshopCC context loss with multiple active files
Hello, I am experiencing loss of context on a project when we open more than one file in PhotoshopCC 2019 using the Shotgun Adobe Panel file integrations. I can open an asset file and save it as a new file, and context displays correctly in the Context Header, particularly the Task (and Step) information. When I open another unrelated asset file and save a new version within the same PS session, context is is updated to the new asset, but the Task info is not displayed. Following that, when I switch back to the original Asset file I have open still, sometimes the context is updated accordingly but is also missing the Task info, but other times remains stuck on the incomplete info from the newer asset, again with no Task info. The behavior is very repeatable, and I get no errors from my console.
Would anyone have any suggestions as to what to look for or try in order to sleuth out the problem? Someone much smarter than me has suggested I add output to context_change.py, to report what I’m actually getting each time I switch active files. Any other suggestions?
Thanks in advance. Michael
I unfortunately have no suggestion but I’m following as we randomly seem to have a similar issue where our Nuke Publish (granted it’s a custom publish hook) picks up the context of the previous publish. And as I havent been able to reproduce it myself I was wondering if this may be a bug somewhere under certain conditions.
To follow up, I have confirmed that it is specific to saving a new file (unconfirmed whether this applies to saving a new version). Using
print engine._CONTEXT_CACHE
in the python console, when I open any published file, the context is good and Task is reported correctly. I can open another published file and both contexts are reported correctly. As soon as I save to a new file, the context is missing the Task information for just the new file. The old published file contexts are still successfully being reported in the cache.
So, is this still buggy, or is this expected behavior with un-published files? I want to say that it’s incorrect/buggy behavior, as you would want to retain Task information for when you actually go to publish the file, so it should still be in context.
I also want to confirm that this applies to saving a new version as well. Task context is lost even when simply versioning up a file, whether it is a work or published file.
Definitely an issue here.
Here is print engine._CONTEXT_CACHE at each point along the way…
Open file…
{‘/Volumes/droid/XXXX/Assets/Information/J/JadeValleyLayoutSketchA/VisDev/Work/Photoshop/GREM_JadeValleyLayoutSketchA_MicahTest_Vd_v34.psd’: <Sgtk Context: Project: {‘type’: ‘Project’, ‘id’: 278, ‘name’: ‘Gremlins’}
Entity: {‘type’: ‘Asset’, ‘id’: 237186, ‘name’: ‘JadeValleyLayoutSketchA’}
Step: {‘type’: ‘Step’, ‘id’: 135, ‘name’: ‘VisualDevelopment’}
Task: {‘type’: ‘Task’, ‘name’: ‘VisDev’, ‘id’: 1693406}
User: {‘type’: ‘HumanUser’, ‘id’: 42, ‘name’: ‘Daniel Eaton’}
Shotgun URL: https://xxx.shotgunstudio.com/detail/Task/1693406
Additional Entities:
Source Entity: None>}
Version Up First File…
{‘/Volumes/droid/XXXX/Assets/Information/J/JadeValleyLayoutSketchA/VisDev/Work/Photoshop/GREM_JadeValleyLayoutSketchA_MicahTest_Vd_v33.psd’: <Sgtk Context: Project: {‘type’: ‘Project’, ‘id’: 278, ‘name’: ‘Gremlins’}
Shouldn’t the CACHE be updated now?
Load Second File…
Source Entity: None>, ‘/Volumes/droid/XXXX/Assets/Characters/T/TestA/Design/Work/Photoshop/GREM_TestA_Poses_Ca_v12.psd’: <Sgtk Context: Project: {‘type’: ‘Project’, ‘id’: 278, ‘name’: ‘Gremlins’}
Entity: {‘type’: ‘Asset’, ‘id’: 237948, ‘name’: ‘TestA’}
Step: {‘type’: ‘Step’, ‘id’: 9, ‘name’: ‘Design’}
Task: {‘type’: ‘Task’, ‘name’: ‘Turn’, ‘id’: 1871667}
Shotgun URL: https://xxx.shotgunstudio.com/detail/Task/1871667
I can see that the context for the previously opened file if wrong. And, if I now switch back to the original file in PS, when the context switches, it is wrong (missing Task because the current path is not in the context and the engine is resolving the context based on the current path).
Now, I save (version up) the second file…
Source Entity: None>, ‘/Volumes/droid/XXXX/Assets/Characters/T/TestA/Design/Work/Photoshop/GREM_TestA_Poses_Tn_v01.psd’: <Sgtk Context: Project: {‘type’: ‘Project’, ‘id’: 278, ‘name’: ‘Gremlins’}
Task: None
Shotgun URL: https://xxx.shotgunstudio.com/detail/Asset/237948
Source Entity: None>, ‘/Volumes/droid/XXXX/Assets/Information/J/JadeValleyLayoutSketchA/VisDev/Work/Photoshop/GREM_JadeValleyLayoutSketchA_MicahTest_Vd_v34.psd’: <Sgtk Context: Project: {‘type’: ‘Project’, ‘id’: 278, ‘name’: ‘Gremlins’}
Task: None
Shotgun URL: https://xxx.shotgunstudio.com/detail/Asset/237186
To me it seems that the _CONTEXT_CACHE is not getting updated after versioning up, so as soon as you switch between files in Photoshop the Context (Task) breaks.
At least this is what I am consistently seeing.
Daniel
Same goes for Publishing. After a Publish the _CONTEXT_CACHE is not updated and returning to that file from another results in a broken context (missing Task).
Am I just missing something here or is this just plain broke.
Daniel
To be more clear. The context.task is correct after a Publish or Save, but when you switch between files and return to it is it wrong.
Hi guys – we have an old bug ticket for this, but it may have slipped through the cracks. I’m going to get more info from the engineering team and report back on its status. Clearly if three people are talking about it here, there are even more who are experiencing it. We’ll keep you posted!
Thanks Tannaz! Would love to know if it’s a bug in the workfiles app or the photoshop engine. Also do we need to file an official ticket of any sort, or will you finding the old existing one and adding our voices to it be enough?
Hiya! The ticket had been closed awhile back when we moved from one system to another. I’ve reopened it, linked this forum post to it, and engineering/product are aware of it. Nothing you guys need to do here; we’ll keep you posted if there’s an update.
Also Hey Wilhelmi! Din’t realize this was you! Great to see you here. :blush:
I know right?! :slight_smile: I’m here with Daniel for a couple more weeks minimum, then we’ll see if they decide to keep me on longer. My previous experience with Nico at Myth is coming in handy though, so hopefully I prove useful enough to keep around. This Shotgun stuff is still hard…
Thanks again for the help. I hope they can find a simple fix for the context issue so it’s a quick update.
Best,
Michael
Was surprised this issue being still unresolved in the latest ShotGrid version. It seems like tk-photoshopcc did not modify the tk-multi-workfiles2 save_as operation, so I copied the hook and extended it like this
elif operation == "save_as":
    doc = self._get_active_document()
    adobe.save_as(doc, file_path)
    # my hook fix is to call the add_to_context_cache
    self.parent.engine._PhotoshopCCEngine__add_to_context_cache(file_path, context)
Similarly tk-photoshopcc the publish finalize hook ignores the newly created version, so I extended the finalize hook as such
# bump the document path to the next version
# changed the call to store the new version path
next_version_path = self._save_to_next_version(path, item, save_callback)
# our context fixing code simply calls the engine's context function
engine._PhotoshopCCEngine__add_to_context_cache(next_version_path, item.context)
Seems like these quick-fixes solved our problems, even if they are a bit hacky. If it helps someone great, but if you see issues in it I would also be grateful, since I am still getting familiar with the hooks in Photoshop.
Hi, (sorry for the thread resurrect). I am running into this issue currently.
photoshop is losing context when performing save_as and publish actions. the issue only shows itself after switching to another document and back again in photoshop.
I have tried the above fix to override the “save_as” operation in the workfiles2 scene_operation hook (updated slightly to point to adobe engine which seems to be in line with latest)
            # my attempt at implementing the above fix
            adobe.__add_to_context_cache(file_path, context)
however i am getting an error during saving saying “Failed to save file <…> JSON is not seralizable”
the context i am giving it is an incorrect format…
is this fix still the best approach to fixing the losing context issue? or is there a better way?
Hi all,
I discovered this myself when I forked tk-config-default2 for our animation productions, and I believe the root of the issue is that the paths for the workfile templates don’t contain any keys/tokens that are associated with individual tasks.
When you open a document in photoshop, or version up with Save As, the photoshop engine calls self._handle_active_document_change() : tk-photoshopcc/engine.py at f27d73eb6de6e06dd686418bd8b0dede098b5883 · shotgunsoftware/tk-photoshopcc · GitHub
Which calls sgtk.context_from_path()… which can’t resolve the task.
The way I solved this since it’s only an issue for our pipeline during publishes, is to modify the tk-multi-publish2 hooks to do some acrobatics to figure out the Task, and present a dialog to the user to select one in the cases where it’s ambiguous.
Another way this could be solved is adding a Task folder to the schema below the Step folder using the task short code or something, which would solve the issue of the Task being returned for the context in sgtk.context_from_path(). I would recommend that only if your coordinators and supervisors don’t want the ability to make Tasks on the fly, since the short codes or whatever name you use in the folder/filenames would probably have to be unique and that takes care from the production people.
As you can see there is no key for the Task in work roots in core/templates.yml
paths:
    shot_root: sequences/{Sequence}/{Shot}/{Step}
    asset_root: assets/{sg_asset_type}/{Asset}/{Step}
You can also use the task id inside the name of the file or the folder so it will be able to resolve it.
